Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 9 inch Ford rear axle seal
Old 11-20-2008, 05:14 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
Originally Posted by SSedan64
Probably has to order because you have the large 3.15 bearing ends. I don't think they're as common as the small ones. I saw some prices for the sealed bearings $28 ea. for small, large bearing & seal $37 @ JustDifferentials
http://www.justdifferentials.com/ind...Path=25_55_337
If his seal is pressed into the housing all by it's self the set 20 is not correct, The set20 uses the 3195 seal and the seal goes on before you press the brg on the axle.
