Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 9 inch Ford rear axle seal
Old 11-20-2008, 05:33 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
If his brg is the BCA88128RB,The alternate number is 514003 BCA,That brg assy will normally use the 51098 seal,common price for that seal is about $7.00.
One other note! The lock ring's in the 514003 axle brg and some of the 88128"s have been a little to thick, So after you tap you seal into the housing and slide the axle in place the lock ring hit's the seal. If you change the axle brg compare the O/A height of the brg and retainer.
