9 inch Ford rear axle seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2008, 12:50 PM
kleen56's Avatar
Does anyone have a part number for a Ford 9 inch rear axle seal? The one I need is for the large early bearing type rearend and I need the seal that goes into the housing. Where is the good place to purchase them? Carquest gave a part # of 6808N with a cost of $28 each? OUCH! It's been 20 years or so since I purchased them and any help would be appreciated.
Ed
Old 11-20-2008, 01:46 PM
prostreet6t9's Avatar
Differential/Driveline
Ed
The 6808N is for a pinion seal for a dana 60,See if carquest has a 51098 seal and see if it's the same.
Old 11-20-2008, 03:15 PM
kleen56's Avatar
Correct! I don't need a pinion seal. I need the axle seal at the ends of the differential tubes. Thanks for the info. I thought something wasn't right with the quote. He also mention the seals had to be ordered. I thought it would be a common part and be in stock. Thanks.
Old 11-20-2008, 03:47 PM
SSedan64's Avatar
Probably has to order because you have the large 3.15 bearing ends. I don't think they're as common as the small ones. I saw some prices for the sealed bearings $28 ea. for small, large bearing & seal $37 @ JustDifferentials
http://www.justdifferentials.com/ind...Path=25_55_337
Old 11-20-2008, 04:14 PM
If his seal is pressed into the housing all by it's self the set 20 is not correct, The set20 uses the 3195 seal and the seal goes on before you press the brg on the axle.
Old 11-20-2008, 04:22 PM
SSedan64's Avatar
Man, Ford makes too many configurations. Nothing interchanges like GM parts do. LOL! I've never worked on a 9", but wish I had one.
Old 11-20-2008, 04:33 PM
If his brg is the BCA88128RB,The alternate number is 514003 BCA,That brg assy will normally use the 51098 seal,common price for that seal is about $7.00.
One other note! The lock ring's in the 514003 axle brg and some of the 88128"s have been a little to thick, So after you tap you seal into the housing and slide the axle in place the lock ring hit's the seal. If you change the axle brg compare the O/A height of the brg and retainer.
Old 11-20-2008, 04:42 PM
I hear ya there! Sometimes the early stuff I have to figure out what brg it has so I can figure out what seal it uses. in the housing.
Old 11-20-2008, 07:28 PM
kleen56's Avatar
Well, I may be jumping the gun here, but I ordered the 51098 seals. I know my axle bearings are the sealed type bearing and the 3.15 diameter. The seals are not on the bearing but inside on the axle tubes. I purchased them from autorock.com on the internet for $2.87 a piece. They get you on the shipping which was $7.00. I bought two seals for $13.38 which includes shipping. Auto parts quoted me $7.99 each but had to order and that would take 2 days. Hope it works. I'll let you know. A big thank you to prostreet for the great info and help.
Ed
rear main seal ate up my crank 406 ss monte Engine 12 01-29-2007 05:31 PM
Need help with 12 bolt rear end pinion seal. cujoe822 Transmission - Rearend 10 09-07-2006 10:47 AM
rear oil seal help alrobjr Engine 5 01-24-2006 07:12 AM
55 chevy, 265 rear main seal slingslingbinks Engine 5 10-19-2004 09:27 AM
65 riviera rear axle seal replacement jartzh Transmission - Rearend 2 10-08-2004 12:42 PM
