Knowledge base
Try our knowledge base..shoul have the info you are after..
OMT
I have found that all the 31 spline axle shafts I have had looked like the above photo. The 28 spline ones have a rectangular slot........or that's been my experience. |
We use a 9" floater rear end from Schreiner Enterprises in our 64 Nova road racer. It's an excellent product.
http://9inchfloater.com/ |
"9 REAREND
I just build 9" for my street rod. The axles were 31 spline
from a 1978 Ford Truck and it had Trac-lok.. However some Lincolns, Merc's, and Ford LTD's also have 31 spline axles. I don't know of any sure way to tell other than pull it and count the splines... If your looking for a Trak-loc, pull the tag from the right side, second bolt down and if it says something like, WFE-AC. The F means its Trak-Loc. And 3L25, L Means Trak-Loc, 3L25 also means its a 3.25 grear ratio. With the other # I might be able to tell your more Onestreetrodder |
I got a nice 31 spline 4 pinion trac lock, with a 350 gear center, Ford 9" center chunk out of a 77 4x4 p/u for $236 i'm going a 31 spline detroit locker or a rebuilt trac loc. look on ebay or on craigs list, in the local news paper ect. there was a lot of em made.
http://www.kevinstang.com/Ninecase.htm http://n.1asphost.com/SETeam/Rearinfo.asp?Page_ID=1 http://www.ford-trucks.com/article/i...ear_Setup.html http://www.maliburacing.com/ford_9_i..._nine_inch.htm Mustangsaly |
I have a rear that is out of a 58-9 Edsel and it looks like this one. It has the large bearings and 28 splines but most of the 31 spline axles do look like this. |
I've got count em 2, 9" complete axles with three holes from a early bronco with big bearings and 28 spline axles. Threw me for a loop when I went and bought a 31 spline spool.
| Rear end swap required & I'm cunfussed | datsun dale | Transmission - Rearend | 8 | 12-17-2008 09:03 AM |
| ford rear end indentifer | 40blackie | Transmission - Rearend | 15 | 01-23-2006 07:39 PM |
| ford rear end help | lolathemustang | Transmission - Rearend | 11 | 01-08-2006 05:55 PM |
| Ford 9 inch rear | sodas38 | Transmission - Rearend | 0 | 05-07-2004 01:38 PM |
| Ford Pickup Rear End | Kaylah | Transmission - Rearend | 6 | 05-09-2003 03:14 PM |
