9 inch ford rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2003, 01:56 PM
New Member
Post 9 inch ford rearend
i found a rearend on my property and was wondering if it is a true ford 9 inch rearend i dont know if chevy made any rearends that looked the same as a ford 9 inch what part numbers do 9 inches have thanx guys
Old 05-24-2003, 03:27 PM
BOBCRMAN@aol.com's Avatar
Post
to the inexperienced a 55-64 chevy or olds-pontiac rear might look like a ford but a 9" ford rear has a seperate bolt on bearing retainer flange just behind the u-joint, also if you can't put a ratchet and socket on the bottom case bolt you probably have a 9".
Old 05-25-2003, 12:43 PM
Post
Hello Martion
Here are some great 9" info links
http://www.ultrastang.com/
Regards
Stefan
Old 01-22-2007, 07:29 PM
estrellam's Avatar
Don't be a fool wrap you tools
This is the site that lets you know everything about a 9 inch
www.kevinstang.com it goes into a lot of detail to identify a ford 9 inch
Old 01-22-2007, 11:08 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Every GM rear that I've seen has GM cast into the center section. and 7 digit numbers cast in.
