9 inch ford setup question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2006, 08:25 PM
Ok this is my first setup i got everything else ok and i just need a opinion before i put it in please.
I need too see if this is one side and this is the other
Does the markings look okay too you on the instructions it says centerd but its ok for them too be close to the toe witch is the inner part of the gear but both of the marks seem to be centerd toward the toe if i take shims out or put in it move them markings to higher and lower that seems to be the centering of the 2 marking. Opinions would be greatly thankful.
ID:	9313   Click image for larger version
Old 01-17-2006, 08:36 PM
Rev It Loud, Drive It Proud!
It seems to look a little tight. Maybe try a thinner pinion support shim. Be sure to keep the proper bearing preload.There shouldnt be any shims except for the pinion support. Good luck
Old 01-17-2006, 08:42 PM
thanks for the reply. what do you mean by losten it up a bit. Sorry this is my first rearend. ive ever done.
Old 01-17-2006, 09:46 PM
I just sent you a PM. Keep us posted. I used the word "tight" for lack of a better word. Sorry if that threw you off.
Old 01-17-2006, 10:13 PM
onestreetrodder
R&P
Eric327
That's not to bad of a pattern.. It should be toward the center of the tooth..But you may not be able to get it there. I have tried, and tried to get there and couldn't..and put it in the car looking like yours, and it worked ok..
onestreetrodder
Old 01-17-2006, 10:58 PM
Ok thanks there aint much more i can do if i take shims away it moves the pattern off center either way adding or subtracting shims. Really thanks for the replys of i was to losten the pinion nut then that would change the preload so i couldnt do it like that and i can move the diferintal over to the left or the right. Cuzz then it would change the backlash. lol so pretty much there aint much i can do. On the instruction sheets it says it ether is closer to the toe or slightly toward the toe and that they are. On another sight ford trucks site it has a mark chart. and it says on there that there is too much heel bearing. I have no clue what a heel bearing is or even if they make one.
Any more reply or any help from anyone is very helpful i just need to make sure or to fix the problem.
Old 01-18-2006, 12:58 PM
i went to a machine shop and he said that the coast side doesnt really matter but the drive side has to be centerd. Because thats where all of the force is.
Here is a drive side picture
Jan18_001
and here is another drive side photo
Jan18_003
and here is the coast side
Coast side
opinions would be greatly apriceated.
ID:	9331   Click image for larger version
ID:	9332   Click image for larger version
Old 01-18-2006, 01:21 PM
1934 Ford Roadster
I have a related question on setting up a Ford 9" please...after everything is assembled including the pinion yoke, what do you all use to seal under the pinion nut to keep the lube from leaking out? I read somewhere that all you need to do is goop it up with some permatex sealer under the nut and torque it to keep the lube from following the yoke spline and leaking past the nut. Is this correct? I replaced the pinion seal in mine and there wasn't any washer under the pinion nut so I used Permatex.
Thanks,
Dan B
Old 01-18-2006, 08:31 PM
nah it shouldnt leak throught there i dont see how it could leak through there cuzz the spline is soo fine and the gear oil is soo thick
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
Ford 9 inch to Chevy 4.75 pattern questions 3100 Special Transmission - Rearend 14 01-21-2006 07:29 AM
1973 Ford 9 inch disc brake conversion question Steve-0321 Suspension - Brakes - Steering 2 12-17-2005 08:47 PM
ford 8 inch amc Transmission - Rearend 10 03-05-2004 08:10 PM
Setup Question (already running) Got Squeeze Engine 3 12-14-2002 10:53 PM
