which 9 inch Ford to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2006, 07:38 AM
'26modelTcoupe283ci
I have two Ford 9" axles and I am trying to figure out which one to use on my 26 model T. One axle is out of a 78 Ford LTD II and I noticed the housing is tapered. The u bolts and leaf spring perches that I was going to use don't quite fit untill you get further from the pumpkin. The other axle is out of a 68 ford F-100 and the axle housing tubes are straight across. Does anyone know if the tapered one is stronger or does it have thinner walls? I have a new detroit locker and bearings to go in them and they both have 28 spline axles so that isn't a concern. Thanks for your help!
Old 02-28-2006, 08:18 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
28 spline is standard the real difference I see would be the gear, meaning the truck will have the quicker ration then the passenger car, however the truck rear is fastest and gas hungry ( if that matters ) If you want a rear to burn tires and quick starts off the line the truck rear is the one. It, the truck rear, I would guess be the stronger of the two , just because of the difference in applications..............imo
Old 02-28-2006, 10:24 AM
Rev It Loud, Drive It Proud!
Use the truck one it has bigger axle shaft bearings.
Old 02-28-2006, 07:17 PM
broncoII88's Avatar
Do the right thing...
Yeah use the truck axel. Who cares about gas mileage. The ratio is probably 3.73 or 4.10. There chould be a tag on the axel somewhere that will tell you what ratio it is. It's a hot rod. Not a Toyota Prius gas saver tree hugger car!
With a Detroit locker, you'll have a very strong rear end.
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
9 inch ford rear end chi-town-st-racer Transmission - Rearend 13 02-22-2006 09:48 AM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
10 bolt 7.5 to ford nine inch big455 Transmission - Rearend 4 10-28-2003 07:34 PM
disc brakes for ford 9 inch Beedog69 Suspension - Brakes - Steering 6 06-04-2002 03:18 PM
