9 inch Housing Question??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2006, 01:22 PM
juveteach's Avatar
BUILD IT RIGHT, TWIST IT TIGHT !!!
Hey guys got a question I thought I'd post because no one else seems to have the answer at the big chassis shops.
I have a 9" housing that I want to run disc brakes on. My brakes are off a 2000 z-28. [I] Is there a special housing end that is made for this application?[/I] I know that I'm not the first with this set up.
Thanks
Old 02-01-2006, 01:24 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Why a different housing end? Just weld on what ever bracket's you need to make it fit. Cut the one off the 2000 camaro for that matter.
Old 02-01-2006, 03:18 PM
302 Z28's Avatar
Don't change the housing ends, if you still have the caliper mounting brackets from the Z see if you can modify them to fit the Ford housing. Worse case is you may have to fabricate some using the Z brackets as a pattern.
Vince
Old 02-02-2006, 07:15 AM
juveteach's Avatar
Ok 10-4,
I can do that, I wasn't sure if I needed the housing ends to be different or not. But I guess I will use the big ends and modify as needed.
Thanks for the help
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
1973 Ford 9 inch disc brake conversion question Steve-0321 Suspension - Brakes - Steering 2 12-17-2005 08:47 PM
BBC cylinder head question Ratoflic Engine 19 11-14-2005 03:22 PM
Header question? HemmiGremmie Engine 6 11-13-2005 02:32 AM
th350 tail shaft / extension housing switch 72BuickGS350Conv Transmission - Rearend 2 10-23-2005 08:34 PM
