9 Inch Open Rear...can it become a posi? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2006, 07:37 PM
I recently bought a street rod with a 9 Inch for rear... its all painted up and pretty, but unfortunately its an open differential without posi (or whatever non-Chevy guys call it) Can a posi carrier be bolted into this rear without a major hassle? Do all the axles, etc. still work? Can I use the same 3.00 gearset? And lastly, where's a good source for rebuilt posi units? I'm not too experienced with Ford rears, but am hoping its an easy change to make... pegleg burnouts aint cool.
Old 11-19-2006, 08:33 PM
Wiki Edits: 49
Sticking a posi unit in a Ford 9" is a piece of cake. Can't help you with used or rebuilt units but new ones are readily available from Summit or Jegs and several others.
A quick search of Summit's catalog came up with this one.
http://store.summitracing.com/partde...5&autoview=sku
Old 11-19-2006, 08:34 PM
Putting a limited slip carrier in a 9" is a relatively easy undertaking. You can buy a third member already set up or you can just put your ring gear on a different carrier. You will need to match the carrier to the axles, as in 28 or 31 spline. 31 spline trac-loc carriers are much easier to come by than 28's.
Old 11-21-2006, 08:54 AM
S10xGN's Avatar
Gotta love a turbo!
Or you can buy a Powertrax locker that will bolt into what you already have. Either way on the 9", the carrier will need to come out, which will involve some specific knowledge and possibly some expensive tools for resetting it...
Russ
Old 12-01-2006, 11:27 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
On the street stick with any of the limited slip differetials, avoid any lockers.
Old 12-01-2006, 11:33 AM
302 Z28's Avatar
The Powertrax unit is not your typical locker. It is very servicable for street use.
Vince
Old 12-02-2006, 01:10 PM
xntrik's Avatar
Vince
That is debatable, of course.
Lot's of people.... ahem.... have pushed the front end off the road when turning in the rain, etc.... even on a highway curve you have to get off the gas ....or else.... no steady power allowed in a turn or it won't unlock.
JMO
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
Rear ends... chrisflock Transmission - Rearend 12 06-04-2005 09:05 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
9 inch Ford Rear End Larry Day Transmission - Rearend 4 02-11-2004 08:27 AM
