9 inch rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2006, 08:00 PM
9 inch rear
i have a 67 chevelle with a 650 hp 383 in it and a tremev tko 600 5speed, i need a rear that will handle that power, i was gonna put a currie 9inch and a detroit locker center section with 3.89 gears but nobody could tell me if that could withstand the power, the last thing i want is to spend $3000 and blow the rear the first weekend> can anybody help me
Old 03-06-2006, 08:32 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
9 inch rear
Check this out, it should answer a lot of your questions.
9'' strength
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 03-08-2006, 04:26 PM
Guy Hiltz's Avatar
9 inch
I have a big block (approx 600 hp) with a Doug Nash 5 speed in my 86 Monte SS and I put a ford 9 inch in it.Mine has the 28 spline axles and it has been in for 3 years now with no problems.Also has bigger brakes on it.I dont race it,but I sure do like to stand on it every now and then.
Old 03-10-2006, 12:40 PM
The reason nobody can tell you if a Currie rearend will hold up is that you haven't provided any info regarding what parts Currie is expected to use. Currie can provide rearends that will range from stock to handling 2000+ hp. Why not tell Currie what you have and what you intend to do with it and let him decide what will work based on logical input rather than having people guessing what components will be used?
I suspect that 3000 dollars is more then enough to set up a rear for that small block.
Old 03-10-2006, 03:03 PM
Glennk's Avatar
9 inch
All I can say is, if you keep standing on those 28 spline axles, the're going to put you some place you won't want to be. 600 hp is too much for those axles. JMHO.....GlennK
Old 03-10-2006, 03:28 PM
camaroman7d's Avatar
The way the question is asked there is no real answer. Yes, Currie makes a rear end that will hold that power. The Detroit Locker will handle it no problem. You will probably want 31 spline axles. You never said what the car was used for or what kind of tires you are running, that makes all the difference in the world. If you are runing basic street radial, you can keep your stock GM 28 spline rear end, because you will never put enough stress on it to hurt it with regular street tires.
I have a blown 388 and I am running a 9" I built using Currie parts, housing, axle tubes, 9+ center section, Detroit Locker, Dutchman Axles, etc... The parts are out there to make a rear end more than strong enough for what you have planned.
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Chevy 1500 Rear Suspension Adjustment after lowering jpd37 Suspension - Brakes - Steering 10 05-31-2005 05:36 AM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
9 inch Ford Rear End Larry Day Transmission - Rearend 4 02-11-2004 08:27 AM
ford 9 inch rear end Nos General Rodding Tech 2 05-18-2003 07:37 PM
