9 inch rear carrier clutch clearance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2010, 06:06 AM
I am rebuilding my rear end and have a problem everything is gone good but I replaced the clutch pack and it seems tight what I mean is when you put the two units together and tighten the two little screws its a liitle hard to metal to metal should I just remove a steel shim I read that it should be about 650.000 of an inch anyone got a idea this is a standard 9 inch 2.891 carier with trak loc posi unit 28 spline axles and big bearings thanks much Transtar cruizer
Old 04-09-2010, 07:22 AM
big gear head's Avatar
High Performance Rear Ends
Wow, use a period and some capitol letters every now and then.
Are you checking it with the springs installed? If you are then take them out until you have everything set right. Is this a Traction Lock differential? If it is then you want it to be slightly loose when it is bolted together with no springs installed. If you set it too tight then it will chatter bad when you turn corners.
Old 04-09-2010, 09:39 PM
merlinsoars's Avatar
Sin Vertis Stratio
I wonder what would happen if we responded in kind, you know one of those three or four paragraph "thingies" with out punctuation..
BTW thanks for the track loc hint
torque link 9 inch rear materials? JEREMY067390 Suspension - Brakes - Steering 0 07-13-2008 03:26 PM
62 Ranch Wagon - 9 inch rear Morgan22 Transmission - Rearend 7 12-04-2007 10:34 PM
9 inch rear end Crazy Man Transmission - Rearend 3 08-26-2003 08:34 PM
TH 350 Intermediate clutch clearance 1969Chevelle Transmission - Rearend 1 08-26-2003 04:34 PM
8.25 rear or 9 inch rear dragrace87 Transmission - Rearend 7 03-20-2003 12:45 PM
