9 inch rearend best ring and pinion ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2011, 08:03 PM
greetings everyone, just aquired a 9 inch rear end,going to put it in my 1954 f100 pickup, could anyone please tell me which is the best gear ratio,i have
a 26 inch wheel base or 15inch tires,chevy 400 trans,406 chevy engine,2500
stall. would like somthing with a good take off,good street and freeway
driving . i was thinking motive gears 3.25,or 3.00 please advise. Thanks
Old 12-14-2011, 11:22 PM
327NUT's Avatar
"a 26 inch wheel base or 15 inch tires" ????????? man that is an awful short car!! Now lets be more specific, what diameter tires will you run on the back and what gear ratio is in the 9 inch you just acquired?
Old 12-15-2011, 02:23 AM
SSedan64's Avatar
Short Truck.
Name:	Short Truck.jpg
Old 12-21-2011, 05:11 PM
[QUOTE=BIG E 86]greetings everyone, just aquired a 9 inch rear end,going to put it in my 1954 f100 pickup, could anyone please tell me which is the best gear ratio,i have
driving . i was thinking motive gears 3.25,or 3.00 please advise. Thanks[/QU
I THINK THE BEST ALL AROUND STREET/GETTIE UP AND GO RATIO WOULD BE 3.73. A LITTLE BETTER MILAGE WOULD BE YOUR 3.25
GOOD LUCK
Old 12-22-2011, 11:09 AM
WHAT wheelbase? Is this a delivery truck for The Lollipop Guild?
Ford 9 inch NASCAR ring and pinion? 96lt4c4 Transmission - Rearend 16 10-17-2011 03:58 PM
9 inch ring pinion installation kit? turchiac Transmission - Rearend 6 02-04-2011 04:41 PM
what ratio ring and pinion should i choose? 66ragtopImpala Transmission - Rearend 4 05-18-2010 05:57 PM
8.5 ring and pinion oldsmo Transmission - Rearend 1 04-19-2006 09:32 AM
What's the formula when counting ring and pinion to get ratio? shockers69 Transmission - Rearend 1 03-22-2004 04:58 PM
