I would like to talk you out of the Ratech kit. They are probably just about the worst kits that you can get.
If you need a kit without bearings then why do you need to know the bearing size? You will need to know which pinion housing you have. The standard housing uses a different inner bearing and spacer than the Daytona housing. |
I needed to know the size because while narrowing my search on summit it asked what size the carrier bearing diameter was, even after i narrowed my results down to kits without bearings, so i didn't know if it was relevant in deciding on a kit. I'm assuming its not a Daytona style because it has raised portions around the bolt holes. Does it matter if the kit i buy is for an open rear or trac-lok? Mine has a Detroit but isn't listed in any of the kits. The kits just say for open or trac-lok.
The reason that it is asking if you have a standard diff or a Trac Lock is because the Track Lock uses different ring gear bolts. Your Detroit Locker uses the same bolts as the standard differential. You probably have the standard pinion housing. The diff bearings will be either 2 7/8 or 3 1/16. The 2 7/8 is the most comon in the stock cases, but if you are not getting bearings then it makes no difference.
The 9 inch kits are probably not that bad, but their 12 bolt and 10 bolt kits have junk shims in them, and I have seen mixed brands of bearings in them. The pinion nuts are usually some generic hardware store nut. I've had problems with their ring gear bolts too.
| Are my ring and pinion still ok? | zildjian4life218 | Transmission - Rearend | 41 | 09-22-2010 11:25 AM |
| 8.5 ring and pinion | oldsmo | Transmission - Rearend | 1 | 04-19-2006 09:32 AM |
| Ring and Pinion | fred56 | Transmission - Rearend | 1 | 01-17-2005 04:45 PM |
| ring and piston installation | mike76 | Engine | 4 | 02-20-2004 12:04 PM |
| ring and pinion help | Pontiacman | Transmission - Rearend | 0 | 11-13-2003 05:09 PM |
