9 inch splines trac-lock alignment - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2007, 08:58 PM
I cannot slide in the driver side left axle splines into carrier?
It looks like the splines are shifted on the drivers side of trac-lock I can see a break in splines and feel the jump with finger.
Is this broken? or is there a way to align splines due to clutches?
Old 07-10-2007, 09:20 PM
I had a similar situation on a GM posi, but I don't know if the solution would apply to yours. I had to remove the preload springs, then stick the axles all the way in to align the splines, then reinstall the preload springs while the splines were aligned.
Old 07-11-2007, 12:22 AM
9 inch splines traction lock
No s spring on traction lock just clutches? not ready to take apart yet?
Old 07-13-2007, 09:06 AM
If the assembly is in the the housing with one axle engaged, you should be able to hold the pinion and rotate the other axle with a prybar while pressing it into the housing thereby aligning the clutch. I have done it a few times but now I make sure the axle will go in before final assembly of the diff.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
low profile tires for 15 inch Halibrand reps peranaman Suspension - Brakes - Steering 3 06-28-2005 04:36 AM
