9 inch wheel bearing issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2008, 07:02 PM
So I slide one side into housing and need to use a large rubber malet to get the wheel bearing/axle into the housing...But the other side slipes in and out by hand alone...No center pumkin in place....What gives????
Thanks
Old 02-21-2008, 07:33 PM
31 five window
Last journal entry: Moving along with patch panels.
Is the tight side rusty? Does the easy side look galled up like a bearing seized and spun in the housing?
Old 02-21-2008, 07:51 PM
No thats whats funny they look great..well i wouldnt say its sloppy just not as tight as the other one..they should be some what of a tight fit should they not????
Old 02-21-2008, 08:12 PM
powerrodsmike's Avatar
Wiki Edits: 161
I've seen them like that, it's no problem. (I like when they slide out easily)
The tightening down happens when you bolt the backing plate on.
Later, mikey
BE different....ACT normal.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
HF English Wheel cboy Garage - Tools 31 03-28-2009 07:15 PM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
Steering wheel decision help guba_unus Suspension - Brakes - Steering 2 02-12-2006 10:21 AM
69 galaxie- wheel size help anyone? RedRobster Hotrodding Basics 2 01-14-2005 05:53 AM
