-   -   9" rear disc brakes problems (http://www.hotrodders.com/forum/9-rear-disc-brakes-problems-225104.html)
AUB72 10-17-2012 01:11 PM
Guys, I had a 9" fabbed for my 1966 Chevelle..it has 5 X 4.75 wheel studs for the GM pattern. I bought the SSBC rear disc kit, and installed it. The disc brake caliper mounting bracket was very hard to get on...holes didn't align and had to be drilled out to fit. NOW, I have the problem where the pads are only contacting the outer half inch of the rotors, and I have a very hard brake pedal, even with four-wheel power discs. SSBC has offered no help. Do I have a wrong bracket for the rear end issue or what? Any advice is greatly appreciated, as I have no experience with 9' rears at all.
bigdog7373 10-17-2012 02:38 PM
I'd say you have the wrong bracket. We're talking a 9 inch ford correct?
AUB72 10-17-2012 02:50 PM
Yeah... 9" Ford with GM calipers
bigdog7373 10-17-2012 02:58 PM
I'm probably not the best person for this question so hopefully someone will chine in here.
In my thinking if you get gm brackets they wont fit the ford axle. And if you get ford brackets they wont fit the gm calipers. If there a bracket that puts the gm caliper on the ford axle? Wait for someone else to answer, this isnt my forte.
timothale 10-17-2012 05:20 PM
which ford 9 ?
Ford used 3 different axle ends on the 9's My old speedway showed the difference sizes, dimensions or google it.
LATECH 10-17-2012 05:22 PM
Sure sounds like the wrong caliper mount to me.
Who built your rear?
Or could the rotors be too small diameter?
I would contact the builder see what he says.
Irelands child 10-17-2012 07:03 PM
Glad that you pointed that out. Many folks aren't aware of that
There is also one more 'caveat' to consider and that's the amount of axle projection outside of the housing which also determines the bracket design. I found that even a couple of aftermarket suppliers had no clue, ECI, being one that blew me off when I talked to them about my '57 small bearing housing but Wilwood knew what to do
Another consideration to the three Ford bearings/axle housing ends is that usually(not always) an aftermarket housing is built with the 'big'/late model Torino version.
bentwings 10-17-2012 07:39 PM
It's possible you have a truck housing. Mine has 3 1/4 in dia tubes. Also a strange "stick out". I don't remember the numbers but they did not match anything in the catalogs. I also have the stock roller bearings. While a PIA they do last longer than the ball bearings.....The seals leak bad so use lots of silicone. Several cruise buddies have the ball bearings and have continuous problems with them especially with deep offset wheels.
I used a Speedway weld on bracket kit and those goofy Seville E-brake calipers.
If you wind up using these you must use a 10 psi residual valve. This is noted in a GM TSB somewhere. This is the only disc brake that needs this. It helps control the piston retraction and thus the pedal travel.
timothale 10-18-2012 07:13 AM
ford parts
Ford did a lot of strange things, changes not always in documentation you can find, passenger car 5 X 4.5 wheel patterns on some light duty pickups in the late 70's early 80's, they did not sell many. I worked there as an engineer and tried to get them to let me keep My bookcase full of Mustang documentation I had in my office, some japanees car companies got confidential information, some people got fired and they were very strict about destroying things that would be valuable to restorers.
Irelands child 10-18-2012 09:59 AM
One of the many reasons Ford products can be 'interesting' to work with.
How well I know about design and trade secrets. We built heavy duty gas turbines. Several folks that I worked alongside, including the bosses boss were caught doing that. Some were walked out the door of infamy never to be seen again, some went to jail. All of my travel records were subpoenaed along with correspondence and my files. Then being investigated by the FBI plus the fact they questioned many of my international contacts - was not a career path aid.
302 Z28 10-19-2012 06:34 PM
In the mid to late 80's when Ford was phasing out the 390 I had the pleasure:pain: of some warranty engine jobs on Ford trucks. I received as new parts from the parts department short blocks with oversized cylinders, reground crankshafts and a host of other rebuilt/remanufactured parts.
Vince
