9" rear disc brakes problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2012, 02:11 PM
Guys, I had a 9" fabbed for my 1966 Chevelle..it has 5 X 4.75 wheel studs for the GM pattern. I bought the SSBC rear disc kit, and installed it. The disc brake caliper mounting bracket was very hard to get on...holes didn't align and had to be drilled out to fit. NOW, I have the problem where the pads are only contacting the outer half inch of the rotors, and I have a very hard brake pedal, even with four-wheel power discs. SSBC has offered no help. Do I have a wrong bracket for the rear end issue or what? Any advice is greatly appreciated, as I have no experience with 9' rears at all.
Old 10-17-2012, 03:38 PM
bigdog7373's Avatar
Of course it's fast
I'd say you have the wrong bracket. We're talking a 9 inch ford correct?
Old 10-17-2012, 03:50 PM
Yeah... 9" Ford with GM calipers
Old 10-17-2012, 03:58 PM
bigdog7373's Avatar
Of course it's fast
I'm probably not the best person for this question so hopefully someone will chine in here.
In my thinking if you get gm brackets they wont fit the ford axle. And if you get ford brackets they wont fit the gm calipers. If there a bracket that puts the gm caliper on the ford axle? Wait for someone else to answer, this isnt my forte.
Old 10-17-2012, 06:20 PM
Wiki Edits: 27
which ford 9 ?
Ford used 3 different axle ends on the 9's My old speedway showed the difference sizes, dimensions or google it.
Old 10-17-2012, 06:22 PM
LATECH's Avatar
Sure sounds like the wrong caliper mount to me.
Who built your rear?
Or could the rotors be too small diameter?
I would contact the builder see what he says.
Fact is stranger than Fiction
Old 10-17-2012, 08:03 PM
Irelands child's Avatar
Glad that you pointed that out. Many folks aren't aware of that
There is also one more 'caveat' to consider and that's the amount of axle projection outside of the housing which also determines the bracket design. I found that even a couple of aftermarket suppliers had no clue, ECI, being one that blew me off when I talked to them about my '57 small bearing housing but Wilwood knew what to do
Another consideration to the three Ford bearings/axle housing ends is that usually(not always) an aftermarket housing is built with the 'big'/late model Torino version.
Irelands child
Old 10-17-2012, 08:39 PM
bentwings's Avatar
bentwings
It's possible you have a truck housing. Mine has 3 1/4 in dia tubes. Also a strange "stick out". I don't remember the numbers but they did not match anything in the catalogs. I also have the stock roller bearings. While a PIA they do last longer than the ball bearings.....The seals leak bad so use lots of silicone. Several cruise buddies have the ball bearings and have continuous problems with them especially with deep offset wheels.
I used a Speedway weld on bracket kit and those goofy Seville E-brake calipers.
If you wind up using these you must use a 10 psi residual valve. This is noted in a GM TSB somewhere. This is the only disc brake that needs this. It helps control the piston retraction and thus the pedal travel.
Old 10-18-2012, 08:13 AM
Wiki Edits: 27
ford parts
Ford did a lot of strange things, changes not always in documentation you can find, passenger car 5 X 4.5 wheel patterns on some light duty pickups in the late 70's early 80's, they did not sell many. I worked there as an engineer and tried to get them to let me keep My bookcase full of Mustang documentation I had in my office, some japanees car companies got confidential information, some people got fired and they were very strict about destroying things that would be valuable to restorers.
Old 10-18-2012, 10:59 AM
One of the many reasons Ford products can be 'interesting' to work with.
How well I know about design and trade secrets. We built heavy duty gas turbines. Several folks that I worked alongside, including the bosses boss were caught doing that. Some were walked out the door of infamy never to be seen again, some went to jail. All of my travel records were subpoenaed along with correspondence and my files. Then being investigated by the FBI plus the fact they questioned many of my international contacts - was not a career path aid.
Irelands child
Old 10-19-2012, 07:34 PM
302 Z28's Avatar
In the mid to late 80's when Ford was phasing out the 390 I had the pleasure of some warranty engine jobs on Ford trucks. I received as new parts from the parts department short blocks with oversized cylinders, reground crankshafts and a host of other rebuilt/remanufactured parts.
Vince
rear disc brakes, ford 9" readdirections Suspension - Brakes - Steering 6 09-08-2006 09:16 PM
Ford 9" w/ rear disc brakes 48Man Suspension - Brakes - Steering 8 07-21-2004 08:58 AM
5.5" Disc Brakes buckethead1 Suspension - Brakes - Steering 1 04-23-2004 09:27 AM
Ford Ranger 8.8" Rear Disc Brakes nightrain_rod Transmission - Rearend 1 06-23-2003 06:48 PM
