9'' rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2007, 12:22 PM
9'' rear end
How much should i be looking to pay for a new 9'' ford 3;50 possitraction rear end
Old 01-16-2007, 05:19 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
New, not rebuilt-reconditioned probably approx $1500 w/posi 3rd member. Can get much more expensive depending on many things like mounting preference, brakes, # of axle splines, alum. or nodular iron 3rd member, etc.
One of many places to get an idea.
http://www.streetrodgarage.com/index...n=Custom&ID=24
Old 01-17-2007, 02:10 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I'd look to Eaton for a limited slip and compare it to Ford TractionLock limited slip. You might also check with Currie for their gear drive limited slip.
Those will run about $ 450, the gears will run about $200, the bearing kits $100, use a solid spacer kit $ 25, pinion yoke $ 90, labor to install into YOUR center chunk $ 150+.
If you need a new chunk housing $$$$.
If you need a new axle housing........$ 600
If you need new axles......$ 300 up with bearings.
Brakes, etc. ????????
Old 01-18-2007, 12:19 AM
327NUT's Avatar
Are you talking about the complete rear including the housing and brakes or just the third member?
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 12:53 PM
Need help with my rear end chevy3600 Transmission - Rearend 3 05-04-2007 06:40 PM
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
