9" REAR FORD L.T.D.? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 12:11 PM
propaneburner's Avatar
Last journal entry: Artillery wheels
Can buy a ford rear axle from a L.T.D. dont know what year.
Can somebody translate the tag for me?
First line WF A-Z 5AC
Second line L00 9 854B
On axle tube 48 5A8 9753
Thanks .
Old 01-28-2006, 10:07 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Thanks .
tag says....
should be one number before the L... probably a 3
3L00 9
3.00 ratio, L for limited slip, 9 for nine inch rear end
854B is date manufactured, year, month, and week of month
Old 01-29-2006, 08:37 AM
spanky36's Avatar
Spanky`s Fix It Shop
9''Rear Ford L.T.D.?
The first line WF A-Z is the axle model the 5AC is the date built code year- month- week. The second line I agree with xntrik that a letter is missing the first letter in the ratio is close to the tag bolt hole and sometimes hard to see.It is no doubt a 3 which would make it a 3.00 ratio traction-lok the 9 is ring gear diameter and the 854B is plant code. Hope this helps you.Spanky
Old 01-29-2006, 02:29 PM
Thanks guys
The first letter on the tag is not visible on the pictures sent to me.
But i understand it has to be a 3.
Anybody know if this axle has big or small end bearings, and 28 or 31 splines.
Sorry but i am not to good with the ford division.
Thanks so far.
Old 01-29-2006, 03:46 PM
rsafreed's Avatar
Rear end
It's probably a large bearing rear...But to know 28/31 spline you may have to pull the axle's and count the splines..There's no other sure way to tell.
Old 01-29-2006, 06:38 PM
xntrik's Avatar
Thanks guys
Thanks so far.
You will have to measure the backing plate bolt pattern dimensions to determine the bearing size. There are 3 (THREE) different bearing sizes for 9 inch Ford rears in cars.
Look at the axle shaft ends that show through the center hole of the wheels. If the hole is a large rectangular oval, it is definitely NOT a 31 spline.
There is a lot of good information on the knowledge base on this site. (and some misinformation) Look there for general information. Google will also get you to tag id charts.
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
ford rear end jay1 Introduce Yourself 1 09-18-2004 03:29 AM
ford 9" rear housing for 70 camaro richrat Transmission - Rearend 1 05-03-2003 10:56 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
9" ford rearend toolmansson Transmission - Rearend 4 02-05-2002 03:14 PM
