9" rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2011, 03:01 AM
dusty019's Avatar
Last journal entry: Keep on keepin' on
9" rearend
Is ther a way to check for a 9" rearend just by looking at the rear end its self? Thanx Dusty
Old 11-03-2011, 08:20 AM
Generally speaking ... YES
If these two nuts cannot be turned by a socket ... it is a 9 inch Ford. If a socket fits on all the nuts ... it is a 8 inch.
Also if the tag is still present ...
You might find this link a interesting read
http://www.kevinstang.com/Ninecase.htm
DEUCE ... Moderator
9" Ford truck rearend w/ 4" offset in A model Roy King Transmission - Rearend 3 03-11-2010 08:37 AM
51" Wide 9" Rearend In A 68 Impala Pro Tourer??? hannes_slanec Transmission - Rearend 19 01-30-2010 11:09 AM
Ford F-250 rearend "sings" cruzinTLT Transmission - Rearend 4 10-07-2007 04:37 AM
How do you measure if 8.5", 8.2" or 7.5" 10-bolt rearend Bigolotava Transmission - Rearend 4 05-05-2004 10:49 PM
Ford 8"or9"rearend James Groves Transmission - Rearend 2 11-28-2001 05:43 AM
