90/91 - 93 AOD Forward Clutch Drum ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2005, 09:03 PM
Did those go to stamped steel like the direct
drums, or did they stay cast iron as in the
older model AOD's?
Also, can the direct drums from the later
model 4R70W's be substituted in the
AODs? In other words, is the size and
spline in the hub for the short stub shaft
in the direct drum in the 4R trans the same
as for the long direct shaft in the AOD?
Thanks!
700r4 forward clutch pack Caesar_Mikey Transmission - Rearend 2 04-17-2005 01:51 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
Needing AOD interm clutch set the clgauge thickness macx Transmission - Rearend 2 11-21-2004 08:03 PM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 08:04 PM
'93 Stang GT Drum Brake Clicking sporks93gt Suspension - Brakes - Steering 2 12-03-2002 09:16 PM
