90 Alero problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2012, 08:58 PM
90 Alero problems
My wifes car, a 90 Olds Alero, 2.4L, is having a problem that I thought was a plugged fuel filter, but I changed it and it still seems to be starving for fuel. When stopped, the idle goes way down, and has a few times died. The check engine light has not came on, so I don't have any idea as to what it could be. I don't want to take it to a mechanic and pay big bucks if it is something simple.. .. .. Any one got any suggestions??
thx
Old 08-17-2012, 09:28 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
They never made an Alero in 1990. That said, I would put a fuel pressure gauge on the valve connected to the fuel rails and see where it's reading and compare that to the factory specs. It's a start.
The Following User Says Thank You to Valkyrie5.7 For This Useful Post:
gfestep (08-17-2012)
Old 08-17-2012, 09:35 PM
OK so it's a 2000
You are right...... I don't know where the 90 came from
thx
Old 08-18-2012, 01:06 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Air
dirty air filter
Fuel
clogged fuel injectors
fuel pump about to go out (get a fuel pressure tester loaner from o'reilly's)
Compression
do a compression test
Ignition
weak spark (coil, plugs, wires, bad ground)
Go to local auto parts store and borrow their code reader. Just because the check engine light isn't on doesn't mean there isn't a few codes in there.
The Following User Says Thank You to Silver Surfer For This Useful Post:
gfestep (08-18-2012)
problems!!!!!!!!!!! 327csb Engine 13 11-04-2011 04:02 PM
2000 olds Alero Door Panel Removal gfestep Interior 1 02-09-2010 01:51 PM
1999 olds alero 2.4 not running on all cylinders. fumplet Engine 1 08-24-2008 07:35 PM
99 olds alero transmission Blob Transmission - Rearend 1 01-27-2008 05:47 PM
Lifter Problems/Head Problems lewisdanw Engine 4 04-16-2006 01:47 PM
