My injectors are not getting a pulse. I have installed a PASSKEY bypass module, this wan't the problem. I have replaced the ECM, nope, either. Changed the Ignition Module on the distributor. Nothing yet. What is my problem.
My SERVICE ENGINE SOON light never goes on. I am starting here. The diagnostic charts are telling me that I have an open ground. I have a test light, vol meter, how do I test for an open ground. I have printed all the electrical diagrams for my car, but have no idea on how to test for an open ground. Please, someone, help me!!! |
Thank you so very much ... like seeing the light at the end of the tunnel, I understand now. If you disconnect a circuit (specifically, give it an open ground), the continuity should be infinite. If it is not, the circuit being tested is taking a shortcut to ground by other means!
Armed with this new information (I am new at this), I was able to test the fuel injectors, the ECM, and the EST. These are my new findings: 1) The EMC is getting a + reference signal from the distributor module (EST). 2) Both injectors are getting 12 volts when key is in the ON position. 3) PASSKEY Module is sending a 2.5-volt signal to the ECM. 4) This is the BIG ONE ... The ECM is sending ground signals to the injectors, but these signals are so weak that it's not enough to light even the injectors test light special tool. It does light up a regular test light, but that's because it is so sensitive. Wrong Solution ------------------- If I give the injectors a good ground -- jump them right to the battery negative, they open up like crazy and the injector test light, when connected, lights up my hole neighborhood. So I thought to install a relay by the injectors to receive the weak ECM ground signal and have it active a good solid ground from the battery and send it to the injectors. I was thinking of making the relay work like a transformer, an amplifier, if you will, for the ground. Then I realized that the ECM is sending a weak signal because something is wrong. It's not that the ECM sends a solid ground and it gets lost somewhere by the time it gets to the injectors. THE ECM IS SENDING A WEAK GROUND, to begin with. Right Solution ------------------ It is obvious that the ECM is not receiving good signals from one of the sensors. I am sure of this because I found underneath my car a broken connector piece. Something is disconnected and that's why the ECM sends a weak ground signal. According to the ECM, conditions with this open connector do not call for a strong ground signal to the injectors. Where do I begin? How many sensors are involved in the ignition process? Please, recommend me a plan of action. Sincerely, Julian Serna |
Are you refering to a noid light? If the ecm is getting a signal from the module, your dist is good, the ecm does grd the injector at varying lengths called pulse width, depending on various inputs, the injector noid lights should pulse rapidly when cranking, maybe your injectors are defective, direct grounding for testing is not a good idea! Check all the ecm grounds and engine grds
Yes, I was refering to a noid light.
Status: I am testing the ECM to ensured it has all good grounds. Question: It's there a relation between EST ground being sent from the distributor to the ECM and the ground being sent from the ECM to the injectors (the pulse width)? In other words, is the EST ground the source of the ground being sent to the injectors by the ECM? |
No,The ECM only grounds the injector circuit directly, but, be sure to check all grounds as they are all common use! The module doesn't send a grd signal. if the noid doesn't flash and you have a reference from the module and good grounds, sounds like ecm fault!
Low signal
Hi,
Docvette here, Had a simular Problem on a V6 chevy van....(at least it sounds simular) If it ran at all , it would last 1 to 5 minutes then not start for 2 to 3 days If then. I did all the checks as outlined here with very much the same results. FIRST may I add, do not try to "ADD" ground or POWER to the injectors...This can burn them up! They relay on a (as I remember) negitive pulse to operate supplied from the ECM. The little coils inside aren't built for high amperage.The B+ is (should be Static) and if I remember correctly, the pulse is 3 to 5 volts ?? After several parts, and shop advice, ton's of newly purchased diagnostic equipment, and 3 weeks of shear agnoy, I found the culprit to be a partially shorted injector, Which (when and if it would start ) Change value with heat, the warmer the engine the more it would short to ground. go out and stay out. and may or may not a few days later. run for 1 to 5 minutes...and so it goes... I got Ohmic values for the coil on the injectors supplied by the local parts guy who dragged one out and measured it, and tested mine to find that my right injector was near short.$73.00 later I was upwardly mobile again. In thinking about it later I wondered why it wouldn't run on the one injector?? at least a little bit.?? I was told, and it seemed plausable, that because the one injector was bad it posed a load on Both injector B+ inputs which are common to each other. I was fat , dumb, and happy, so at that point, I really didn't care. The problem never re ~occured again. ... So maybe another place to check?? ...Oh goody..... Hope this helps a little Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Thank you all for your help. It turns out that the problem was a bad VATS module. This is the module for the security system. The systems involved are the ignition cylinder, the VATS module and the ECM. Well, rather than replacing the ignition cylinder or the VATS sytem, I hoot up with www.tbichips.com. They burn me an EPROM chip for $50.00 that totally bypasses the VATS system and that got my car started. Only problems was giving the starter relay a constant ground which I did.
Solution!
Juilian,
Doc Here: Glad To here you have Resolved The Problem! Fine Job! What Was it Bell Labs Said in the Late Forties....?? Computers Were on the Horizon.. .And They Were Going to make Life Sooo Much Easier and Faster For The Bi~pedal Multi~celled Species... THEY: Never Stood in a line at Albertsons with 12 people in front of him, 2 quarts of melting ice cream , 3 Screaming Kids, and a Code Scanner That malfunctions 1 out of 3 times... OR lost his pay check in the ATM deposit door.... Was Able to WATCH his luggage go to the Pyrenees Islands on a Computer Screen... at his destination Airport.... Tokyo Japan... Relied on A computer Generated Voice To tell him 5 minutes after sitting on the side of the road stalled...."WARNING...LOW FUEL" ...HAH! lot you know...you don't even know the difference between a "DOOR" and a "JAR"..... Computers....Can't live with them...... Well, enough on that subject.... Glad to Hear you are Back on the Road! Doc ![]() =========== Yes, your bathtub is more dangerous than flying, but it's rare to be killed by shredding aluminum and burning aviation fuel in there.
