90 chev trk problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2013, 05:27 PM
vht vht is offline
90 chev trk problem
I've got a friends 90 chev, 4x4, 3/4 T, 5.7 std shift trk. The problem is when you hit the throttle it boggs. Setting still you can roll into it easy and the rpm will go up, on the road you have to barely give it gas and get into high gear as quick as possible and try not to put into any extra load to get any speed up. It has a new tank, lines, FP, and rebuilt throttle body from a problem 2 mths ago. I've cked map, FP press, ECM, Dist, grds, and you name it. It had a O2 circ code and wouldn't go into closed loop, fixed that and installed new plugs, they were fouled, and put a new gm cap and rotor. Tried a good coil I had here also. No codes now and everything on data list looks good. Starts and idles great, hit the throttle, setting still, and it starts to rpm and then just boggs or flattens out. Adding or taking away fuel doesn't help. Has anyone got any ideas because I'm out.
Old 04-08-2013, 06:05 PM
LATECH's Avatar
Drop the exhaust system right from the manifolds. The cats may be plugged. If Dropping the pipes clears it up, then the exhaust is plugged.
Fact is stranger than Fiction
Old 04-08-2013, 07:02 PM
vht vht is offline
No cats and the exh was just put on. Went over it with a temp gun. But that is the way it acts.
rocker oiling problem chev 235 jrbrandt Engine 1 02-02-2012 08:41 PM
40 Chev S/R Overheating Problem jjohncochrane@juno.c General Rodding Tech 2 08-17-2011 10:57 AM
Chev S 10 starting problem: Ford Wagon Engine 1 02-02-2009 06:39 PM
New to site.1942 chev trk shaved1 Introduce Yourself 4 06-26-2008 02:21 PM
85 Olds to Chev fan shroud problem oldsmo Engine 4 03-26-2006 08:45 AM
