90 Chevy Silverado 4/wheel drive not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2009, 04:55 PM
RAYFIN's Avatar
Last journal entry: before picture
My shop truck was in 4 wheel drive and now it isn't. 90 Chevy Silverado. V8 Automatic 350. Isn't there an electric switch on the transfer case or is it the front axle? THe fuse keeps blowing that says 4wd, but I think it's just this switch thing. When It fisrt stopped working the fuse was not blown. It's like it just quit working. Worked fine for years. Any way to check this?
Last edited by OneMoreTime; 01-23-2009 at 05:28 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 01-23-2009, 04:57 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I don't know if you will get answers for this in the interior forum..
Old 01-23-2009, 05:29 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Moving on to proper forum..
Sam
Old 01-23-2009, 07:03 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
My buddy has an '88 GMC that had the connector on the backside of the front diff. come unplugged. The light stayed on, but it was stuck in 2wd. Plugged it in, worked just fine. After removing a small mountain of snow from the area of course....
In a while, Chet.
Old 01-24-2009, 06:47 AM
There is a switch on the t-case and an actuator on the front diff. When mine went out it popped the fuse too. GM has an upgrade kit that lets you use the new style actuator. I highly reccomend it.
Shane
Old 01-24-2009, 09:41 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
It also depends on which one your truck has as to what went wrong with it.
There is the well known bad thermal actuator (TLA or Thermal Linear Actuator) , and the electronic actuator.
Just a ballpark figure (you might be able to find it priced vastly different) My catalog shows the TLA actuator for $110, the electronic actuator for $170, and a 4X4 posi-lok for $300.
There may also be other manufacturers of a cable operated interaxle locking kit for a vastly different price. but at least the cable reacts NOW, and has less of a chance of failing.
Old 01-25-2009, 08:24 PM
RAYFIN's Avatar
Thanks so much guys. That helps alot. I couldn't find ***** in my manual.
Old 12-02-2010, 10:47 PM
RAYFIN's Avatar
It was the switch thing on the front axle. (actuator)
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
327 Small Block Chevy that dies when I drive it EazyDuzIt102 Engine 17 04-06-2009 10:49 PM
'88-'98 Chevy Silverado dannimo Interior 1 08-13-2003 08:53 AM
1999 Chevy Silverado Transfer Case/Transmission? officialfoxracer21 Transmission - Rearend 2 12-15-2002 04:56 PM
chevy can run in drive ringo Engine 1 12-08-2002 08:12 AM
