90 Chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2008, 10:21 PM
90 Chevy truck
I have a 90 Chevy truck with a blown motor but I have 305 with casting #378450 heads. I tried putting the tbi intake on this motor but the 2 bolt holes in the middle of the intake does not match up all the way. I would really like to use this motor in the truck but the intake is my only problem. Every thing else seems to bolt right on the motor. What can I do about this problem.
Old 10-14-2008, 11:47 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
The center intake bolts are not compatible. You need a pre-TBI intake.
Old 10-15-2008, 01:20 AM
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
i believe you can get an adapter to mount the TBI unit on the old intake.
another possible option, i've seen a number of people grind on the center bolt holes to elongate them & then use washers & silicone to cover and seal the holes.
Help! what frame to put under a chevy 1 1/2 ton truck? Riley Hotrodding Basics 10 02-15-2009 08:15 AM
s-10 front clip on a 50's chevy truck smokinbrinkman Suspension - Brakes - Steering 6 07-08-2008 11:48 AM
54' Chevy Truck paddlin4reds Introduce Yourself 3 11-28-2007 01:34 PM
New '48 Chevy Truck seen in Classic Trucks Turkey Hotrodders' Lounge 4 11-28-2005 07:09 PM
1967 Chevy Truck Gear Ratio 53chev Transmission - Rearend 3 01-27-2005 07:49 PM
