Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 90 Chevy Truck Brake Pedal sinks after stop.
Old 07-20-2011, 07:53 AM
pemdj pemdj is offline
The ABS Hydraulic Unit ( Isolation/Dump Valve ) was stuck in the bypass position causing a constant internal leak. I replaced the ABS Hydraulic unit , bled the brakes and now they work perfect. I was told that this is a common problem for these trucks.
