90 degree racing manifold..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2005, 02:22 AM
correct me if i'm wrong, but shouldn't intake manifolds like these be a little more curved from the plenum into the runners? isn't a sharp 90 degree turn horrible for performance?http://store1.yimg.com/I/machevo_1862_6439780
Old 09-04-2005, 03:35 AM
Yes.
Yes.
I think you need to understand that in this case:
Racing = lacks all smog provisions and can't be driven on the street.
It might make more power then a stock manifold but not as much as if it had proper radii and equal distribution.
Don't forget that proper bell mouths are expensive.
Old 09-04-2005, 07:43 AM
Banned
Well, the runner's would actually be a lot better IMO if the plenum was bigger to allow for better flow distribution.
Where is manifold vacuum port on Quadrajet 4mv? dr-data Engine 10 12-13-2005 05:41 PM
Weiand Manifold question Andrew7dg Engine 1 08-30-2004 01:03 AM
'97 crate 350 - what edelbrock manifold? THC3PO Engine 5 06-28-2004 05:56 PM
anyone ever install kugel 90 degree brake unit? jimmy p Suspension - Brakes - Steering 10 06-05-2004 07:09 AM
90 degree offset u joint caps?? catscan4free Transmission - Rearend 4 01-29-2004 11:29 AM
