90' gmc 1500 gauge cluster to 93' suburban cluster - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2009, 07:10 AM
I'm having some problems rewiring a 93 suburban gauge cluster to my 90 gmc 1500 dash. the reason for my doing this was because of the needle readouts, and a tach. the problem i'm having is with the wire colors not matching up. the vss wire should be a blue with black stripe wire, but i dont have one at all on my harness. plus after i figured out most of the wires, i found that there were 6 extra wires coming from the older cluster, but dont goto the newer one. the book doesnt even say anything about them. so i tried to hook everything up and see if it worked, everything worked but the speedo did not. Has anyone ever dont this swap before and have the same problems? Any ideas for solving this?
97 gmc 1500 97 GMC 1500 Internal transmission squeak Longbox262 Transmission - Rearend 5 06-25-2008 05:41 PM
Installing Nordskog Digital Gauge Cluster In 84' Cutlass labreejr Hotrodding Basics 0 05-29-2008 09:48 AM
Guages are dead gtipton Electrical 4 05-09-2007 09:14 PM
El Camino gauge cluster swap? BT74 Interior 1 02-06-2004 08:49 AM
VORTEC in a '93 Suburban? 68NovaSS Engine 1 11-09-2002 12:55 PM
