Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 90 Grand Am 2.5L Tranny still pulling when stopping.
Old 07-27-2011, 01:02 AM
mike 96 ws6's Avatar
mike 96 ws6 mike 96 ws6 is offline
old dog learning new tricks
I replaced the bottom pan and filter with no problem = done.
Then I pulled the pan off the drivers side end of the tranny and only see 1 solenoid in there (I assume this is the TCC solenoid?) 14 photo's of my current situation with this solenoid can be seen here .
As you can see the solenoid I pulled out has 1 bolt hole to fasten it and one of the wires is much longer than the part I purchased from NAPA.. And the solenoid I received from NAPA has 2 bolt holes.
I assume NAPA gave me the wrong part but I'm not even sure I'm working with the correct solenoid?
What am I doing wrong?
