90 Grand Am 2.5L Tranny still pulling when stopping. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2011, 10:58 PM
mike 96 ws6's Avatar
old dog learning new tricks
This car has been sitting for 2 years due to a bad coil and leaking front main seal.
I fixed the coil and seal and it runs and shifts fine, but when I test drove it on the interstate it seemed like the converter stayed locked and the engine stalled when I came to a stop (like stopping in a car with a manual transmission without pushing the clutch in). I cranked it up and shifted to 'D' and the motor stalled, several times. Then I cranked the motor and shifted to reverse and the motor stayed running so I shifted to 'D' and it returned to normal operation (although now it doesn't feel like the converter is locking at highway speed.
What to do now?
Thanks,
Mike
Old 07-25-2011, 04:01 AM
Torque convertor lockup sensor/switch. Easy to fix. Common problem on those GM frontdrivers.
Old 07-25-2011, 08:00 AM
tnsmith10's Avatar
when will it rain???
What to do now?
Thanks,
Mike
the 125 has had toque converter solenoid problems for years and is more than likely the culprit with the trans.
the easiest and cleanest way to go about it would be to drop the bottom pan and do a filter change, this will keep the the trans from leaking all over when the side cover is pulled to swap out the solenoid. and since it would be a good idea to service the trans anyway, that is why i suggest a new filter at the same time.
Old 07-25-2011, 08:57 AM
I had exactly this problem in a 1990 Grand Am. It's a PITA to replace the solenoid, as clearance between the side cover and the inner fender is minimal. It now runs fine.
Old 07-25-2011, 01:40 PM
tnsmith10's Avatar
the lower frame on these cars are real simple to separate from the body and allows the back of the trans to drop well enough to make the side cover an easy removal.
Old 07-25-2011, 01:50 PM
Is there a way to disable the converter from locking?
I only ask this because the car belongs to my neighbor, a 93 year old lady who only needs the car to get around town to the grocery store and church, and she has very little money. She should not need to go faster than ~ 40 mph.
Can I permanently jumper the OBD1 ALDL connector to keep the ECM in test mode, therefore disable ling the converter lock-up?
Thanks for the help everybody!
Old 07-25-2011, 03:29 PM
Never mind, I tried jumpering the ALDL connector and the problem still exist.
Next issue: I've called 3 GM dealership parts departments to order a "Torque converter control solenoid". One of which said the part is no longer available, and the other two dealers said they could not find a part listed for this vehicle as a "TCC solenoid".
How can I find a part # to maybe help these guys find my part?
Old 07-25-2011, 03:46 PM
Next issue:
VIN is 1G2NE14U5LC369650
Old 07-25-2011, 05:21 PM
Get a wiring diagram and remove the wire from the trans that actuates the TCC solenoid.
Old 07-25-2011, 08:45 PM
tnsmith10's Avatar
the dealers probably havent had a 125 come through their doors much since the beginning of the millenia.
your probably going to have to get the solenoid through a trans shop that sells parts. some do and some dont.
the harness connector that goes in through the case is for lockup only, this is something i wouldnt normally recommend but, with what your describing on the activities of the car, i cant say it would hurt much. that connector can be unplugged and unless there is a physical problem with the solenoid, it wont engage lock up anymore.
Old 07-25-2011, 10:56 PM
fast68's Avatar
likes chevy trucks & boobies
i always unplug the connector on front of the trans case and call it good
works
perfectly driveable this way, dont worry about it after yuo unplug it
put a bottle of seal conditioner fluid in the tranny the red colored fluid additive, not the lucas or other crap
this will keep it going for a long long time and help all the old dried up hardened seals inside the tranny and VB
its dirt cheap and can only help it and weve brought back alot of dead trannies with the stuff
Old 07-25-2011, 11:46 PM
I talked to her before I checked back to this thread and today her daughter raised enough $ for a filter, fluid and TCC solenoid. I ordered through a local auto parts store (they confirmed the part description listed "converter solenoid" for $32).
Just for diagnostic sake I'll unplug the harness connector and test drive prior to pulling anything apart.
Maybe we can get grandma rollin' tomorrow.
Thanks again!!!
Old 07-26-2011, 03:20 AM
I had a cavalier that did the same thing. I just unplug ed the wires that run to the lockup. square shaped plug on the front of the trans. to disable the lockup. trans worked fine ever sense then. a Friend has A grand am same thing still driving years later
Old 07-27-2011, 02:02 AM
I replaced the bottom pan and filter with no problem = done.
Then I pulled the pan off the drivers side end of the tranny and only see 1 solenoid in there (I assume this is the TCC solenoid?) 14 photo's of my current situation with this solenoid can be seen here .
As you can see the solenoid I pulled out has 1 bolt hole to fasten it and one of the wires is much longer than the part I purchased from NAPA.. And the solenoid I received from NAPA has 2 bolt holes.
I assume NAPA gave me the wrong part but I'm not even sure I'm working with the correct solenoid?
What am I doing wrong?
Old 07-27-2011, 08:42 AM
tnsmith10's Avatar
by the looks of things, that is a "fitzall" brand universal lockup solenoid with napa boxing. it will work on both the 440t4 and the 125.
as far as the wiring goes, the short black wire needs to be cut close on the old solenoid and the wires need to be spliced so it can be joined to the new solenoid. the red wire can be cut pretty much anywhere you want as long as the the wire from the new solenoid can reach where you cut the old wire.
if i remember right, one side of the "tangs" that come on the new solenoid should be able to be removed for use on the 125.
theres nothing wrong with the solenoid you bought, its just going to take some extra effort to hook it up.
clear as mud? or did what i typed make sense? hopefully it makes sense and youll be able to get it going. if not, ill do what i can to help get it straightened out.
1986 Grand Prix Tranny Upgrade GrandPrix8686 Transmission - Rearend 10 12-16-2009 06:05 AM
Tranny problems in 2000 Grand Am Bluebow762 Transmission - Rearend 12 06-01-2008 12:05 PM
Need some help pulling motor and tranny??? 49fordp/u Hotrodding Basics 8 05-17-2008 12:29 PM
Pulling motor/ tranny 66 C10 66thom Engine 6 10-27-2003 10:46 AM
pulling tranny without pulling motor.... Rubberman2003 Transmission - Rearend 20 06-26-2003 10:11 PM
