904 torqueflight rebuild tutorial ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2010, 02:11 AM
I have been looking around the site for a rebuild tutorial on a 904 lockup torqueflight trans simular to the great TH350 tutorial by jakeshoe. Is there one on the site that I have just not found? if there is not one here does anyone have any good links to one ?
Many thanks Mark
Old 10-26-2010, 03:01 AM
SSedan64's Avatar
Google 904 trans rebuild
Old 10-26-2010, 03:35 AM
Ive done that but there dont seem to be a tutorial that is as good as what jakeshoe has posted up here. this will be my first trans rebuild so Im just trying to get the best head start I can
Old 11-09-2010, 03:31 PM
cranky1's Avatar
Just stuck
Well, this isn't on the lock up but a 904.... http://www.moparmusclemagazine.com/h...ild/index.html
You might get someone that has a manual if you visit some of the mopar specific sites like moparstyle dot com forbbodiesonly dot com forabodiesonly dot com and some others. You can do a search for those and other sites.
Old 11-09-2010, 03:35 PM
Thanks for your reply cranky1 I will take a look
Old 11-09-2010, 04:54 PM
904 is really simple you almost cant mess it up if you pull it apart and lay everything out in order its basically a small 727. I like doing these I really like the 518 and the REs
Old 11-09-2010, 04:56 PM
here is a exploded view
Old 11-09-2010, 11:52 PM
Thanks for the picture trans builder Im quessing by your name this is what you do so I have a furture question and that is when I order the parts for the rebuild I have seen that the friction clucthes come in 2 different thicnesses so how do I determine what thickness clucthes I need ? As Im in the Uk I am going to order these parts in the US and have them shipped back to the UK so need to get the oder right.
Thanks
Old 11-10-2010, 09:43 AM
I just looked on my suppliers parts list and all i show is direct frictions .086 and forward frictions .061 I dont see any other options as far as thickness unless you are looking up some kind of special pack that uses thinner frictions to add more clutches. The 904 is really an easy trans to do order yourself an ATSG manual and you shouldnt have any problems. if you do have a problem feel free to ask.
Old 11-10-2010, 09:58 AM
Thanks transbuilder is you suppliers list online attall ? so I to could take a look ? Im not sure if you can post links up on this site but you could allways PM me the Link. Ps what other parts would you recomend that I 100% change whilst I have the trans apart ? It is to be mated to a 360 Magnun with about 350 HP.
Thanks
Old 11-10-2010, 10:11 AM
Call Will at 407-522-4417 tell him Robert sent you he is my supplier from Whatever it takes trans parts. replace the sprags and bushings and new band maybe a decent shift kit. the 904 isnt a weak trans in its design as it closley mirrors the 727 just smaller. If i were you I would look at doing a 727 swap if you can find one or maybe even a 518 which is basically a 727 with a OD unit onthe back of it. they can be found at yards pretty cheap. Big ugly MOFOS but they are hella strong. I have had 5 on the bench in the past 2 months they have their issues but its usually a fault in the cooler lines that kils them. the checkvalve gets stuck and cuts lube oil to the OD unit and wipes out the rear of the trans, but i rarley see any probs with the main case.
Old 11-10-2010, 03:20 PM
SSedan64's Avatar
I agree the 727 Trans would be a better choice but, if you only have the 904 available, you have to use what you have.
Here's a few sites for parts.
http://www.makcotransmissionparts.com/A904.html
https://www.wittrans.com/Schematic.a...nsmission=A904
http://www.transmissionpartsusa.com/...rts_s/1326.htm
http://www.transpartsonline.com/tpfi...sPartsType=904
Old 11-10-2010, 06:01 PM
Thanks for all your replys here is where im at with my choice of parts
TF2 shift kit
koleene steels
Alto red eagle clutches
bushing kit 4.2 bilet lever
HD band strut 2nd gear
overhaul kit
new filter Brass or Dacron ?
And as far as bands are concerned I dont have a clue so any suggestions for a street car but able to handle some good power 350-400 HP also what sort of torque connverter would you guys suggest car weighs in at about 2500 lbs
3.5 rear gear and 26 inch tyres. and if there is any thing else I have missed let me know
Thanks
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 03:04 PM
700R4 Rebuild Parts and Advise Questions wild_man84 Transmission - Rearend 37 04-09-2010 05:07 PM
Holley 4160 rebuild tutorial online? Chefasaurus Engine 9 06-20-2009 10:47 AM
904 TorqueFlite rebuild cost? pi71 Transmission - Rearend 5 08-07-2007 02:00 PM
Which rebuild kit? leastbay Engine 7 12-19-2004 03:19 PM
