904 trans problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2002, 02:03 PM
Unhappy 904 trans problem
i just put my rebuilt 904 torquefight back in my 69 cuda ....drove 10 miles ...got on the gas a bit to see how she would shift under strain. and i got no forward gears now. reverse got me home .
can reverse still work if i lost my converter . it does go in gear on jack stands ...but it only goes in reverse on the ground...?
Old 09-24-2002, 04:00 PM
dklong's Avatar
Post
69cuda sounds like the forward clutch is gone, i'm not sure if that trans has adjustable bans or not.if it does they may need adjusting . check your fluid level and condition first, if burnt smell trans is gone, if ok , check your shift linkage for adjustment if ok . check with your local trans shop about adjusting the bans.
