90's T-bird IRS on my '68 Cat - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2004, 04:46 PM
Last journal entry: IRS mock-up
Lately I've been playing with the idea of putting a mid 90's T-bird LX IRS under my '68 Cougar. The wheel spacing is almost perfect (69 inches on the T-bird vs. 68 1\2 on the cat). Threw a measuring tape on the frames too and the T-bird IRS' front mounting points are within 2 1\2 inches of the inside of my cat's frame. The rear mounting points seem a bit dicier. I think they are 5 inches too far in. It's nothing a good cross member can't fix. I'm fairly sure I can "convince" the assembly to fit, but that's not really my problem (although any input would definately be welcome). My question is, since this is my first rear suspension project, just how accurate do I have to be? Do I have any leeway; can the rear be realigned if I'm off 1\8 or so or will I have to rip it all out and start over?
Old 08-03-2004, 09:40 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Rear install
Short answer is that you need to be very accurate in doing this,,other wise the car may "dogwalk",, measure 3/4 times clamp tite weld once..others have done this so you can to if you like,,
The ideal is to use the adjustments for the very minimum of necessary minor alignment of the rear whells..
Old 08-03-2004, 09:01 PM
Well, I guess I'm going to find out how well I can read a tape measure.
Thanks for the info.
