91 350 chevy no spark no inj pulse - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2008, 08:29 PM
WOW i have never seen something like this in my life! i'm ready to pull my hair out! ok..... i have a 90 chevy w/t that came with the 4.3 and standard tranny. i got a 91 silverado from a friend that had a cracked frame so i took the motor from it, and computer wiring harness and ecm and put it in my truck. ran great! still had the original wiring harness in it. later i wanted to changed the heater box assembly to the push button style from the slide style so i used the same under the dash wiring harness that came from the donor truck and put it in. now it won't start. replaced the coil, dist, and ecm. still no start. went to do a voltage check and the ingition wire on the steering colum and the truck started... then started it a few more times after that. a few days later went to start it again and it did but only for a few second before i just started to spit and spudder then died. now won't start at all. everything but the steering colum os from the other truck. engine, wiring harness for the ecm, and under the dash harness for the fuse block and ecm.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 09:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 06:46 AM
Will my Buick 350 (1970) fit into my 1984 Chevy K10? GFORCECONSTRUCTION Engine 0 05-22-2006 08:58 PM
350 buick in chevy truck? jrm123180 Engine 7 04-04-2004 12:03 AM
91 chevy 350 problem HELP!!!! slyshar2 Engine 10 03-29-2004 02:23 AM
