-   -   91 4x4 5 speed s10, clutch install problems (http://www.hotrodders.com/forum/91-4x4-5-speed-s10-clutch-install-problems-208700.html)
tcn71nova 11-13-2011 10:56 PM
i have a 91 4x4 5 speed s10 that i am putting a clutch in i got the trans out and new clutch in but i try to put the trans back in and i can only get the trans high enough to get the shaft to the forks on the pressure plate and then i cant get it ant higher it seems like i am hitting the pinch weld on the firewall and floor any ideas on how to get this thing in the truck
S10 Racer 11-14-2011 12:07 AM
You might try jacking up the front of the motor to tilt it back while you bolt up the tranny.
tnsmith10 11-14-2011 06:07 AM
unbolt the exhaust from the manifolds...
