91 4x4 5 speed s10, clutch install problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2011, 11:56 PM
i have a 91 4x4 5 speed s10 that i am putting a clutch in i got the trans out and new clutch in but i try to put the trans back in and i can only get the trans high enough to get the shaft to the forks on the pressure plate and then i cant get it ant higher it seems like i am hitting the pinch weld on the firewall and floor any ideas on how to get this thing in the truck
Old 11-14-2011, 01:07 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
You might try jacking up the front of the motor to tilt it back while you bolt up the tranny.
Old 11-14-2011, 07:07 AM
tnsmith10's Avatar
when will it rain???
unbolt the exhaust from the manifolds...
S10 5 speed clutch disc Mrwood Transmission - Rearend 9 11-09-2010 01:09 AM
I'm sharing a t-400 trick to install those pesky clutch piston seals Big Buick Transmission - Rearend 4 07-19-2010 08:48 AM
clutch/pressure plate install question levens Transmission - Rearend 4 12-30-2004 10:37 PM
Clutch problems 95 camaro 5 speed namdlo Transmission - Rearend 1 06-22-2004 10:39 AM
do I need to install a stall speed? the ernster Transmission - Rearend 2 04-13-2003 09:59 AM
