91 c1500 5.7 timing problems
searched most threads, still can't determine how to seat distributor completely. I'm at TDC with no alignement marks on distr. shaft.. reason I pulled, had missfire, no acceleration. and I've installed new tank, filters and TBI. still have same problems. detected no vacuum leaks spraying around TBI, no CEL on. removed distr. cap and rotor is pointing straight ahead down center of intake, instead of pointing toward no. 1 cylinder. do I ccw oil pump shaft, so rotor, when seated is pointed toward cyl #1? thanks, ya'll are the best!!
thanks bro. for the response. I've decided that it was put in wrong prior to me owning. since its run poorly since i bought it. I set TDC and removed distr. to retime. just noticed on some other threads they said to point rotor to the 6 or 8 mark on housing. mine has neither. so i was gonna time it like I done my 4.3 once. Get TDC and seat distr. in with rotor pointing toward cyl. 1. just really needed a little reassuring. thanks
Are you disconnecting the timing wire before setting the timing? The connector needs to be disconnected, then set the timing to "0", then reconnect the timing wire.
yessir, got it timed to 0. with wire unplugged. feel good about that, still has miss. new tank, pump, sending unit, filter, and new tbi with new injectors. recently installed wires plugs, cap, and rotor. startin to think distibutor itself is bad. got me stumped. rechecked all plug wires and plugs. no CEL on.
The pickup coil in the distributor is a common problem with these. They are cheap, so you may want to consider replacing it anyway.
Cobalt guess that'll be next step. Pretuner is that the black bolt-on inside of cap? just changed it, too.
Also, the magnet on the reluctor in the dizzy was known to crack and cause all kinds of headaches, from random misfires, stalls, low power, no starts, ect. I've seen this several times.
Did you change the plugs and wires? I would assume so but you didn't mention it.
kinda threw me a min. Cobalt on that vacuum advance, knew it didn't have that, lol. but I'm leaning toward that whole dizzy being bad. Has had a slight miss for two years I owned, progressively got worse. Now it almost stalls out if i get on it. and have changed plugs and wires, and rechecked individually. Wish fatherinlaw was still around, had big salvage yard here in AL. had plenty of extra parts to try when he was around,, never been puzzled this bad before, something minor just can't put my hands on it yet. Thanks everyone again, I luv this site!!!!!!!!
The injectors are also fired from the pickup coil. Take a look at the spray with a timing light and the engine running. Should be smooth on each injector.
I think that's my problem, both injectors are pulsating with the firing. Gonna yank the dizzy out. Hard to believe bad compression or springs. Had one valve cover off, motor is clean as a pen, don't burn oil or nothing. Clean lil truck inside and out. thanks everyone, take me couple days to get back, I'll let ya'll know how it goes!!
| Tags |
| 5.7 distributor, timing |
| 1988 chevy c1500 problems | Ufcmaniac | Transmission - Rearend | 6 | 10-19-2011 07:12 AM |
| tcc problems in 1990 c1500 | liljohnalan | Transmission - Rearend | 5 | 01-08-2011 07:44 AM |
| 1996 Chevy c1500 4L60e problems | osiris419 | Transmission - Rearend | 5 | 10-05-2009 05:17 PM |
| 89 c1500 700r4 shift problems or toast? | slammedchevy1500 | Transmission - Rearend | 12 | 12-30-2008 09:34 AM |
| Timing Problems | 80 Chevy C10 | Engine | 15 | 09-12-2002 08:33 PM |
