91 camaro cluster problems HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2007, 09:50 PM
My 91 camaro has a new gauge cluster in it only reading 15000 miles and the speedo works when it wants to. It seems like when the car warms up (about 15 min going down the road) when i hit a bump the speedo starts working but it jumps around then doesent work again. Or if I manualy shift the trans it some times starts working but soon doesent again. Also my tach is a little crazy acting too. Sometimes it reads 1000 rpm off but if I smack right below the dash it seems to read correctly. What do I need to do. What do I need To check. Is my VSS out, What should it read When I stick my meter to it. Could my tack need a new filter. Help Please
Old 09-08-2007, 11:03 PM
njbloodline666's Avatar
I Love VTec
clean your grounds and your connection to the cluster, see what happens then... iirc the 91 has gauges for oil pressure, temp and volts.... are they acting normal?
problems with a arms on a 67 camaro catcherdan Suspension - Brakes - Steering 7 04-19-2006 03:34 AM
87 camaro 700r4 problems Dans83Olds Transmission - Rearend 3 03-13-2006 05:16 PM
72 camaro nose on a 78 camaro roy383ci Body - Exterior 3 02-25-2006 05:59 PM
91 camaro lookin for 5 speed non-comp ace29816 Transmission - Rearend 0 02-09-2006 10:38 PM
camaro z 28 tranny shifting problems chevcamz28newbie Transmission - Rearend 8 07-22-2003 07:43 PM
