91 camaro T5 stock transmission to a 355 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2011, 07:10 PM
I new to the forum and hotrodding in general. I recently bought a Datsun 240Z and would like to swap the old 2.4l L6 motor for a 350 SBC. Ideally i would like to make about 350 hp at the wheels.
I have an opportunity to buy a T5 out of a 91 camaro to use in my car. I was wondering if this would be a good manual 5 speed transmission to go for with a 355 sbc making about 350rwhp.
Old 01-07-2011, 09:07 PM
big gear head's Avatar
High Performance Rear Ends
The T5 was only used with engines up to 305 cu in. They were not rated for enough torque to handle anything more than the 305. Your 355 will probably break it unless you are easy on it.
Old 01-08-2011, 09:33 AM
Any recommendations as to what a good 5 or 6 speed manual trans would be to use with a 355 sbc?
Old 01-08-2011, 10:38 AM
Tremec makes some pretty good 5 speed transmissions.
stock 350 vortec in a camaro cam advice. dany7018 Engine 6 05-12-2009 05:17 PM
89 camaro F body stock rearend width? eatonde Transmission - Rearend 2 01-05-2009 11:20 AM
stock 350 transmission camaro86 Transmission - Rearend 4 02-27-2008 09:19 AM
Can i supercharge a stock 427T? Going in 86 Iroc Camaro. Shawn MacAnanny Engine 9 03-24-2006 02:12 PM
how can i control my transmission with out stock comp?? scheetz93 Transmission - Rearend 2 04-23-2004 02:09 PM
