91 chevy pu 350tbi running problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2008, 05:29 PM
Where to start i have a 91 chevy pickup with a 350tbi 213,000 miles Truck has a problem starting and staying running runs rough and will die and wont start again for a while when it finally decides to start it will idle pretty good then it will jump up to 1400 rpm give it a little gas and will die and of course won't start again. it's getting fuel it also puts out black smoke under power
I have replaced or checked the follwing
egr valve
ecm
ignition module
fuel pump
gave it a full tune up
fuel filter
throttle sensor
Please help thanks Chris
Old 06-07-2008, 05:32 PM
King of my Man-cave.
egr valve
ecm
ignition module
fuel pump
fuel filter
throttle sensor
O2 sensors are probably history by now.
tom
Old 06-07-2008, 05:37 PM
Thanks Tom i will try that now
Old 06-07-2008, 06:16 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Check your PCV valve operation, and look for any vacuum leaks, including the crankcase for a intake gasket vacuum leak. Pull the throttle body and clean out the PCV port on the bottom, and remove the idle air control valve, and clean the pin-tel and port out.
The O'2 sensor is most likely history and would have been my first guess along with fuel pressure. Normally 8-15 psi on your vehicle.
Also take the exhaust pipes loose at the manifolds and see if it will rev up. The catalytic converter could be plugged, causing your engine to not be able to "fart".
My 2 cents worth.
Old 06-07-2008, 06:18 PM
racecar100's Avatar
There one small tempature sensor on the intake mainfold next to the thermosat housing is bad and cause one to puff out black smoke. Unplug it and see if it run..
Old 06-08-2008, 06:34 PM
I had the same type of issue with my 88 with 293K on it the temp sensor and conector took care of it. The O2 sensors don't do anything till they get to 600 degrees and put the ECU in closed loop.
Old 06-08-2008, 06:52 PM
Good call. A faulty engine coolant temperature sensor (NOT coolant temperature sending unit) will tell the computer that the engine is stone cold ALL the time, resulting in an over-rich mixture, regardless of real ambient temperature.
But the O2 sensors are probably waxed, too.
tom
Old 06-08-2008, 07:12 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Leaky injectors are common on the TBIs. That would cause the issues you're describing
Old 06-09-2008, 11:22 AM
n-gin's Avatar
BrraaAAAAP!
Take a reading of the intake vacume. Also check to see if the intake gasket has sucked in and actually causing vacume in the crank case. To check take your pcv out and see if you have a vacume in the valve cover.
Black smoke is caused by a lot of things. Leaking intake. Leaking egr. temp sensor, o2 can be lazy too. That just a few things.
It sure sounds like a fuel related problem. You did not specify the psi you have on your fuel. Best thing to do is put a psi gauge on the fuel rail, most of the tbi did not have a shradder valve, so your might have to dead head the system into the gauge. It will read higher with it dead headed about 40-75 psi. Sometimes you can just pull the return line off and see if it sprays out of the tbi. If it just leaks out or trikkles a little then you have a bad fuel pump.
I have had the egr valves not leak through the pintle but leak through the base to valve. So depending on how you tested the egr will give you different results. I take the valve off and put exhaust gasket matterial between the intake and the egr vavle with no holes except the bolts. That way you know that the valve is not leaking in any way.
I would check the base timing too. Along with timing chain slack. Take the dist. cap of and turn the engine by hand take note of how far the crank moves before the rotor starts to turn.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1987 Chevy Tbi Problems hiball Engine 6 02-10-2007 05:15 PM
My Chevy is running better with a Ford part on it. CrashFarmer2 Hotrodders' Lounge 3 12-08-2006 10:02 AM
help please chevy 350 problems wickedenvy Hotrodding Basics 14 08-15-2006 09:23 AM
ID Plate, 50 chevy pu, goes where fat50chevy Body - Exterior 3 08-11-2005 11:39 AM
