91 ciera tilt column issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2009, 12:49 PM
fast68's Avatar
likes chevy trucks & boobies
well i have come across alot of loose tilt screws over the years and repaired them etc, but currently we have a 91 ciera cutlass FWD car here and the tilt(just for some reason that i cant explain) doesnt seem to have the same kind of sloppiness that you usually find with just loose tilt screws
although it doesnt seem broken or anythin else. and plus it is a FWD column and not a RWD column that are kinda different from each other internally,
when you pick up on the column it also moves the column shift handle fore and aft
would this be simple due to loose screws?
doesnt move side to side
and the slop in the column is about the same as for completely looose tilt screws
but it just seems different to me this time for some reason,
what do you think ?
i kinda just wanted to get some opinions before i tear the column down
1978 Camaro Tilt Steering column CamaroHunter78 Interior 5 02-14-2008 03:19 PM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 12:36 PM
steering rack to column issue waynesworld Suspension - Brakes - Steering 1 06-25-2006 04:20 PM
GM tilt column Busted Knuckles Suspension - Brakes - Steering 3 11-07-2002 08:11 PM
Chevy Tilt Steering Column James Groves Suspension - Brakes - Steering 1 11-20-2001 05:12 PM
