-   -   91 explorer (http://www.hotrodders.com/forum/91-explorer-56005.html)
jasonmenefee 01-13-2005 07:37 PM
91 explorer
hi again i have an 91 explorer witn an automatic trans the problem is if you put it in overdrive on the colume it doesnt go into gear at all if you go back to park and then drive it takes right off also there is a problem with the rear antilock brakes the truck wont go into gear until the antilock light comes on how is this tied to the trans any help with these problems would be app thank you
red65mustang 01-14-2005 05:46 AM
Your Explorer is not safe to drive, take it to a good local repair shop.
pmeisel 01-14-2005 08:36 AM
Sounds like a linkage problem, a good repair shop should be able to fix pronto.
poncho62 01-14-2005 10:13 AM
I agree with the linkage prognosis.....................
Wasn't there a recall by Ford in the 90s about transmissions dropping out of Park into Reverse? May be related.
