91 explorer - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2005, 08:37 PM
91 explorer
hi again i have an 91 explorer witn an automatic trans the problem is if you put it in overdrive on the colume it doesnt go into gear at all if you go back to park and then drive it takes right off also there is a problem with the rear antilock brakes the truck wont go into gear until the antilock light comes on how is this tied to the trans any help with these problems would be app thank you
Old 01-14-2005, 06:46 AM
Your Explorer is not safe to drive, take it to a good local repair shop.
Old 01-14-2005, 09:36 AM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
Sounds like a linkage problem, a good repair shop should be able to fix pronto.
Old 01-14-2005, 11:13 AM
poncho62's Avatar
Wiki Edits: 5
I agree with the linkage prognosis.....................
Wasn't there a recall by Ford in the 90s about transmissions dropping out of Park into Reverse? May be related.
