91 ford ranger 2.9l v6 4*4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2011, 06:29 PM
hello, i wonder if anyone out there can help with this issue that is driving me crazy. my ranger runs fine then it shuts off at any given time as I'm driving . something is cutting the fuel from the injectors. the engine does turn over ( spins) but does not start. after i get it towed home( did that few times) it starts right after or sometimes not untill the following day. i replaced the ignition module, spak plugs,wires, coil, dist. cap and rotor. checked the fuel pump, checks ok. checked the celenoid, ok. help...........................
Old 03-23-2011, 01:12 AM
Wiki Edits: 31
check for stored codes.. my guess would be the fuel preassure regulator. they rupture and suck gas down the intake. doesn't take much to badly flood out a 2.9... other would be the ECU. they have been known to go thermal and need replacing. but there also fairly inexpensive at a JY
36 Ford Pickup on a Ford Ranger Frame? Fasteddy General Rodding Tech 21 12-08-2012 12:25 PM
1997 Ford Ford Ranger gear ratio ? mercury man Transmission - Rearend 8 03-23-2008 03:10 PM
'98-'08 Ford Ranger Frame w/ '37 Ford Body? jbundick Hotrodders' Lounge 8 12-28-2007 06:31 PM
Ford Ranger JSD Performance Hotrodders' Lounge 2 03-04-2006 01:47 PM
96 ford ranger 96ranger Engine 2 09-20-2002 12:40 AM
