91 gm 7.625 rear end question???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2006, 09:03 PM
Hello I've got a quick question, what are the tell tale signs of a rear end that is about to go? Plus does anyone know where I could get a posi rebuild kit for my axel, I've had no luck trying to track one down and all the replacement posi units I've found are all for V6 apps, any help would be great. Thanx Guys
Old 04-27-2006, 01:01 AM
What is it under? If it is under an S10 it won't have a "Posi" (aka limited slip) is will have a Gov-lock. If it is the gov-lock don't rebuild it...ditch it for something else. If it is a car axle ignore that.
Is it making clunking and chirping when you make turns? When you accelerate?
Old 05-01-2006, 09:22 PM
91 gm 7.625" rear end question??
The rear end is in my 1991 Z28. one wheel does slip out around corners and on hard acceleration plus it has pulsating vibrations from it plus it almost feels like it slips just a little before grabbing. the u-joints are brand new. and the tranny is a new B&M 700-r4 with a 2500 stall converter.
Rear end ratio question timothy9972 Transmission - Rearend 14 03-28-2006 05:25 PM
82-92 camaro posi rear end info NoEgoMan100 Transmission - Rearend 4 10-21-2005 03:22 PM
7.5 rear end performance question 1BADSS-10 Transmission - Rearend 2 12-16-2004 08:45 PM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 08:14 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
