91 Mustang Airbag Ques - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2006, 06:24 PM
I just bought a 91 mustang, it has a 2.3 engine and the airbag light is on, i tried scanning it real quick with our solus but i could'nt find the airbag codes, i'll try again next weekend.
But someone mentioned that there is a clock spring that goes bad? where is it and you think that this is broke?
Thanks
Brendan
Old 03-13-2006, 10:28 AM
Thanks
Brendan
Count the flashes of the airbag lamp after turning ignition on. A code 32 is usually a clockcpring. code 51 is a blown fuse in the module.
Old 03-13-2006, 11:28 AM
ok, what are the flashes for each? when u say fuse in the module is that inside the steering wheel?
Brendan
Old 03-13-2006, 12:22 PM
Brendan
There is an internal fuse in the airbag module which is a blue box behind the center of your dash,usually the clockspring has an intermitant short that blows the non replacable fuse. You have to replace the clockspring and the module.
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Will a 390 fit or work in a 73 Mustang..... onebadmerc Engine 4 12-08-2005 09:57 AM
91 mustang throw out bearing jajeff22 Transmission - Rearend 9 02-20-2004 11:37 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
forward tilting hood '91 Mustang BlueNoser Body - Exterior 1 01-02-2003 07:12 PM
