"91 octane ok??" - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2011, 03:53 PM
1bad32's Avatar
"91 octane ok??"
I just bought this engine for My '32 Ford coupe that is being built.
Can I get away with using 91 octane,,that's all there is in lovely L.A. or should I probably use some octane boost as well.
Thanks
566 Horsepower, 383 Small Block Chevy, GM 350 - 4-Bolt Main Block with ARP Main Bolts, Double Keyed Eagle Cast Steel Stroker Crank, Eagle Rods, Comp Cams Hydraulic Roller Cam and Lifters, Double Roller Timing Chain and Gears, Polished Aluminum Timing Cover, Polished Aluminum Finned Oil Pan, Double Keyed Pro Products Balancer, Complete Rotating Assembly Balanced, Forged 8.2 to 1 Compression Blower Pistons, File Fit Moly Rings, Polished 64cc Aluminum Heads with Manley Stainless Steel Valves, Chrome Moly Retainers and Locks, Comp Cams Springs, ARP Screw-in 7/16 Studs, Stainless Steel Roller Rockers, Polished Aluminum Valve Covers, Polished Intake with Stainless Hardware, Polished 671 Supercharger, 3 Inch Drive Pulleys and Belt, 2 Edelbrock 750 Carbs, Linkage, Fuel Lines, Funnycar Style Belt Guard, Polished Dual Carb Scoop with K&N Filters, Mallory Ignition, Set up, Run, Synchronized and Dynoed.
Old 10-15-2011, 05:38 PM
BOBCRMAN@aol.com's Avatar
I run my blown 383 sbc in the "T" bucket on the 91 stuff or worse. All the time. Just watch the spark advance at lower rpm. Use a cam with a lot of compression loss (overlap) at low speeds..
Old 10-15-2011, 05:58 PM
1bad32's Avatar
That sounds good!
Old 10-15-2011, 10:25 PM
327NUT's Avatar
I'm originally from So. Cal.....if you don't mind saying, who built the engine?
Old 10-16-2011, 08:32 AM
1bad32's Avatar
Al's toy box back east,,any comments are welcomed!!
Old 10-16-2011, 02:40 PM
Thumpin455's Avatar
Ask me about Ethanol
Last journal entry: 65 GTO
You can get something better at all these stations, plenty of octane, cheaper than 91, makes more power, runs cooler, and all you need to do to run it is swap or modify the carbs. You cant say it isnt available in the area, and once you try it, you will love it with the blower.
Conserv Fuel, 11699 San Vicente Blvd, Los Angeles, California
Chevron Propel, 102 E. Huntington Dr, Arcadia, California
Chevron, 100 West Foothill Blvd, Pomona, California
Propel, 12042 E Firestone Blvd, Norwalk, California
Royce Chevron, 1250 Sepulveda Blvd, Harbor City, California
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
Covering stock "plastic" door panels with "vinyl" csilva84 Interior 1 10-05-2007 06:30 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
