91 ranger 2.3 cracked Oil pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2013, 04:31 PM
LATECH's Avatar
Last journal entry: New Gas Tank
I have a guy with a cracked oil pan on a 91 ranger 2.3.
Its an aluminum pan, and its cracked at the rear on both sides of the rear main / main saddle area.
A young buck owns it. 5 Speed standard.
I think he was thrashing it. Anyone else see this ?
Fact is stranger than Fiction
Old 01-22-2013, 05:17 AM
engineczar's Avatar
I've never seen it on the aluminum pans but I see it all the time on the stock steel ones. We end up filling the outer edge with additional weld and not over torque it.
BSE Racing Engines
Old 01-22-2013, 08:10 AM
Wiki Edits: 27
loose bolts
If he had some loose bell housing bolts that might let let things move and fatigue the metal. the oil pan was designed to tie the bottom half of the bell housing to the engine, thru the oil pan. make everything rigid so the bell housing wouldn't have to be so beefy.
Old 01-22-2013, 04:51 PM
LATECH's Avatar
Just put a clutch in it. Bolts are all tight. Just wasnt sure if abuse by the young owner could have cracked it. Excessive thrust/ dumping the clutch etc .
Will oil pan seal with one broken oil pan bolt? Dougie Engine 2 03-10-2011 08:29 PM
400 SBC oil pan question..What quart size of pan do I need? heathj1 Engine 10 07-26-2010 08:26 PM
86 Ranger 2.3 AT PS TBI Continued Emmisions Failures / Oil Pan Leak jmacs53Willys Engine 2 03-23-2009 04:46 PM
351w oil pan/ 5.0 oil pan interchange? problem solvers Hotrodders Site Suggestions and Help 4 05-10-2006 08:36 PM
Water in oil, cracked block? FASTCHEVY Engine 13 12-23-2005 11:33 AM
