91 s-10 auto tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2007, 10:20 AM
Prof. T. Soggmeyer's Avatar
Plan B
91 s-10 auto tranny
Hi this may sound dumb, but...is the outomatic tranny from a 91 s-10 a 700-r?
And if it is can it be made to be used in my 49 chebby on my 283 without all the fancy electronic stuff. Maybe there is a kit that bypasses a computer if that is the case.
Thanx in advance,...Brad...
Old 04-22-2007, 11:03 AM
racer rick's Avatar
youre trans is actually a 4l60e .e is for eltronic so it needs all the computer junk to operate. if you want a od trans you need to find a 88 or older 700
Old 04-22-2007, 11:57 AM
Did the computer control the transmission in 91? I may be wrong, but I thought that started with '94 up. In '91 it was just a 4l60, not the 4l60e. crosley and some others can answer this a whole lot better. Even if it is computer controled you can buy a kit that will make it work, only it is then manually shifted and down. Good luck.
Old 04-22-2007, 01:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
racer rick ; your information is incorrect.... 1993 was the first year of the 4L60E trans. You want a 1988 - 1992 4L60 trans to build. In 1993 the vette and F body cars had non electronic 4L60 trans also
Prof. T. Soggmeyer;
IF the S-10 had a 4.3 V-6 , the trans will have the proper bell housing pattern for a V-8 chevy engine.
the 1991 S-10 would have a 4L60 non electronic controlled trans..... many companys offer a kit to lock up the torque converter clutch.
The TV cable on the trans is very important , must be hooked up and operate correctly .
Old 04-22-2007, 05:38 PM
Plan B
s-10 trans
Thanx a million guys! It sounds to me like this is even a better trans than the 700 r. Any hints where these kits can be had?If I can talk the guy out of it, I'll get it. It ought to fit real nice between my 283 and 12 bolt. I just want a daily 49 3100 that I can feel good about.
Man this site rocks!!
Brad out.......
Old 04-22-2007, 06:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Brad out.......
sorry I was not clear...... a 4L60 is a renamed 700r4 trans.
torque specs for a flex plate on a chevy 350 to auto tranny badk5 Engine 1 07-01-2005 06:56 AM
3speed auto tranny? TonyMac Transmission - Rearend 3 01-09-2005 09:26 AM
Ever have this happen to your tranny? Help BudLight Transmission - Rearend 6 06-12-2004 09:21 AM
95 sonoma tranny problem 383MontecarloSS Transmission - Rearend 0 05-29-2004 01:25 PM
help with tranny munbers notmrgoodwrench Transmission - Rearend 2 01-23-2004 09:59 PM
